These are in good shape, with some light surface rust on one of the case-side ODs (looks worse in the photo than reality) and some old oil staining in the bores/on the pistons. Hatching looks brand new because they've never been run. Head-side OD is 108mm, case side is 106mm.
I don't know if these are better than the AA biral P+C's (probably), and I'm sure they aren't better than anything coming out of LN Engineering, but they are from an era when most VW aftermarket parts were of high quality, esp coming out of Japan. I would not hesitate to run these, increase displacement and improve cooling.
The case itself has been cleaned up and opened up for these P+C's. I never had heads done unfortunately (if I did, I'd probably have the engine built). I do have the one missing head stud from the photo - somewhere.
Probably not interested in shipping these due to size/expense/risk of damage. Local pickup is the best plan. I might make it out to Hershey which could be a good hand off point too.
Not entirely sure what these are worth, but lets start at
Please let me know if you have any questions.
-Chris
