Where is the fuse to a factory six fuel pump. I've looked at the books I have but can't find it.
Is it the 30 amp fuse on the relay board?
Thanks
Gene
toolguy
Mar 1 2016, 12:48 PM
Unfused, direct feed from the ignition switch same as the cd box
xsurfer
Mar 1 2016, 02:12 PM
QUOTE(toolguy @ Mar 1 2016, 10:48 AM)
Is there a relay to remove or do I have to remove the power wire at the pump?
Thanks!!
Peashooter
Mar 1 2016, 02:56 PM
The feed to the fuel pump is direct from the ignition key, no relay or fuse. You would have to disconnect the wires at the pump or interrupt the wire coming off the switch.
