Hi all Can anyone please tell what the eyelet in the approx. centre of the rear trunk carpet is for? I have found a threaded hole in the trunk below where the eyelet would be but cant work out what is supposed to be held there? Steve
914Next
Mar 3 2016, 07:44 PM
QUOTE(Creamsicle New Zealand @ Mar 3 2016, 08:36 PM)
I believe that is there to allow moving the spare tire to the rear truck with using the hold-down bolt like the front truck.
Mar 3 2016, 08:39 PM
QUOTE(914Next @ Mar 3 2016, 05:44 PM)
To secure a spare tire using the same hardware that is used in the front trunk.
Mar 3 2016, 09:40 PM
Thanks for that, hadn't thought of putting the spare in the rear but I can imaging the extra height in the front trunk gained by doing that.
Dave_Darling
Mar 4 2016, 10:26 AM
The extra space is enough to fit the big cooler full of beer...
--DD
worn
Mar 4 2016, 10:45 AM
QUOTE(Dave_Darling @ Mar 4 2016, 08:26 AM)
--DD
Yet I wonder if you would be willing to shift the balance that much towards the nose. Are you saying with or without ice?
Ansbacher
Mar 4 2016, 11:08 AM
So, which is better for balance- spare in the front or spare in the back? I presently have my spare in the front trunk plus some tools, while there is nothing in the rear trunk.
Ansbacher
Steve
Mar 4 2016, 11:18 AM
QUOTE(Ansbacher @ Mar 4 2016, 09:08 AM)
Ansbacher
I was told the car has a 49/51 weight distribution, so having it in the front is preferred. Also if the spare is in the stock position it is also part of the front impact zone, which could save your life.
Mar 4 2016, 12:22 PM
QUOTE(Steve @ Mar 4 2016, 09:18 AM)
struckn
Mar 4 2016, 02:40 PM
I find the ride to be better with the weight of the spare up front and the handling also better for general driving.
wes
Mar 4 2016, 04:25 PM
Ya but if you want it to Handel more like a 911 put the spare in the back
forrestkhaag
Mar 4 2016, 07:03 PM
I moved the spare to the rear trunk, secured it with the hardware, put the top back in the rear trunk, and stuffed a side shift tranny and all the linkage in the front trunk for the ride back to Laguna Beach from Phoenix (Craig's List purchase) .. tons of room. - wouldn't fit in the rear trunk...... and I still had room for a hitchhiker.....
ClayPerrine
Mar 6 2016, 11:54 AM
QUOTE(worn @ Mar 4 2016, 10:45 AM)
--DD
From experience:
You can put a pony keg in the front, and pack ice around it. Then drive to your party, open the front and tap the keg. The small holes in the trunk will let the water from the melting ice run out onto the ground.
r_towle
Mar 6 2016, 02:30 PM
I wonder how wide of a tire you could put in the rear trunk and still be able to put the roof in there.
TheCabinetmaker
Mar 6 2016, 02:46 PM
QUOTE(ClayPerrine @ Mar 6 2016, 12:54 PM)
--DD
From experience:
An old girlfriend and I put would put a case of beer on ice in the front trunk and lawn chairs in the rear. Then we spent the evening at the admiral twin drive in watching movies. Btw, it's still showing movies and the only remaining twin screen drive in, and still on route 66.
Mar 6 2016, 02:59 PM
QUOTE(r_towle @ Mar 6 2016, 12:30 PM)
225/50 x 15 on a 7" cookie cutter rim is the max i can fit in there. The roof does touch the tire and doesn't fit into the rear rubber holders anymore but the lid still closes.
A 205 tire on a 5.5" or 6" rim should fit just fine without touching ...
