Compression is mid 90s across the board. Leakdown is nil.
This is the original motor and mileage.
I have a spare GA block that I wanted to freshen up and then swap to freshen up the matching GA block.
I picked up some stainless exhaust for it as well.
Need to change fuel lines to stainless and replace motor/trans mounts and oil cooler seals.
Other than painting the tin, that is about it.
Has a little rust in the usual areas I am going to tackle, waiting on replacement gun for my MIG.
Then I will get around to painting it.
SO, bumping up to 96, or cam replacement does not require any modification to the MPS?
I have researched and read a lot about bumping it up slightly, needing minimal adjustments. That appears to be the key to a slight bump?
I do the work myself, so I was figuring about 2K for a rebuild. The forums have been extremely helpful and THANKS to everyone here who has posted their knowledge and experience!
I about fell down the other day when the MRS said why don't you finally do what you want to do to the Porsche... so I am using this limited window I see on the horizon!
It is my understanding that the stock MPS settings can handle the 2056 without any tweaking. When you deviate from the stock cam, some minor tweaking may be necessary. I'm still waiting for the verdict on what cam I'm going with. I told my cam guy that if a slight upgrade from the stock cam will require MPS tweaking, I'd rather stay stock.
Oil cooler seals can be replaced with the engine in the car. I'd run that engine and build on your spare block so you have a plug & play replacement when the time comes. Our cars spend way too much time "getting built."
