I bought a '75 core to rebuild and finally got it open up.
Just a couple of questions to start:
1) Is it possible to inspect the syncros, dog teeth, and sliders without removal? I have the output shaft off and can see that 1st and 2nd are worn. The input shaft with 4th/5th look good so I'd rather not remove the shaft if not needed. The teeth don't look worn and both 4th and 5th syncro bands are black.
2) Do the sliders tend to wear faster than the dog teeth? My 2nd gear dog teeth actually look okay, but the slider on the 2nd gear side is definitely worn.
Probably doesn't tell a lot, but I included some 2nd and 3rd gear photos.
