QUOTE(porschetub @ Mar 12 2016, 10:52 AM)
QUOTE(396 @ Mar 12 2016, 11:22 AM)
QUOTE(Valy @ Mar 11 2016, 01:17 PM)
I just use the HF stand with its included yolk.
Works very well.
I'm sure that the basic HF will suit a type 4. But based on my little brain, it's best to pay for the 4 / 5 arm engine yolk for anyone working on a - 6. Especially if you want to access everything at once, unless you like to remove the engine off the stand every time you might want to unbolt the cooler and clutch assembly.
,NEVER use a standard type yoke on a 6 engine unless you have little concern for your case or ,you can however add a conversion yoke to them and they are ok.
I used a heavy duty VW style yoke I made many years ago sleeved and welded to the common V8 type stand,the 6 cyl motor is to valuable to hang of anything else,frankly I wouldn't risk a T4 in the same way.
A lot of hype here, many have used the universal adaptor that comes with the engine stand when building a six with no issue. I use the adaptor ring that fastens to the universal to build a fully dressed early 930 motor, no problem. The P201 tool only attaches to the case at 2 points, you want the strength of several attachment points so that the tool doesn't bend and can support the weight of the engine as you're building. IMO, I was happy to have the 4 points of the universal attached to the adaptor ring, any fewer and the engine would get a little bouncy while torquing things as you build.
The advantage of the special tool (or adaptor ring) is that it attaches to one case half, and it's notched and grooved to sit flush on the face of the case. It also allows enough room to add/remove the flywheel and the tins. The p201 gives you a bit more room than the adaptor ring, but both sill work. If you used the universal that comes with the case, you attach at 4 points (2 on each case half) and you lose the ability to remove flywheel and split the case without removing and resetting the holder.
As with anything, use common sense, check the mounting and stress points regularly for cracks or bends. Finally, quit overthinking and dive into that motor!
