Aaron Cox
Mar 23 2005, 06:16 PM
the instructions implicitly say " This is the only wire to touch the negative/positive side of the coil"
currently i use the + side of the coil for a 12V switched positive source....
after hooking up the CDI... there should only be the CDI wires on the coil.... where can i find another switched + in the engine bay?
skline
Mar 23 2005, 06:20 PM
Here is the picture of your engine. Too bad it was pouring down rain. Probably looks much better dry with the sun shining.
Aaron Cox
thx scott!
skline
Mar 23 2005, 06:21 PM
You know, its funny that you kind of look like the guy in your avatar, do you wear glasses??
Aaron Cox
Mar 23 2005, 06:24 PM
anyway.....
can anyone answer my CDI question?
Trekkor
Mar 23 2005, 06:27 PM
QUOTE |
where can i find another switched + in the engine bay? |
Easy.
On the relay board where the F.I. four pin harness plugs in.
Use the terminal closest to the driver and the motor.
Looking at it as a compass, North-East position.
KT
Aaron Cox
Mar 23 2005, 06:28 PM
QUOTE (trekkor @ Mar 23 2005, 05:27 PM) |
QUOTE | where can i find another switched + in the engine bay? |
Easy.
On the relay board where the F.I. four pin harness plugs in. Use the terminal closest to the driver and the motor. Looking at it as a compass, North-East position.
KT |
im running my fuel pump off that
ArtechnikA
Mar 23 2005, 06:33 PM
QUOTE (Aaron Cox @ Mar 23 2005, 07:28 PM) |
im running my fuel pump off that |
is this an ignition that has a BIG wire to the unswitched +12?
if so, the switched wire is used only to switch on the unit, not actually power the ignition, and won't draw any significant current.
lacking that - the relay that probably isn't used for the heated rear window in your car should get switched +12.
or - have a look at a wiring diagram and see where Terminal 15 or Terminal 30 show up back there.
or - use the wire currently attached to your fuel pump to trigger a relay, and draw current for both from that.
spunone
Mar 23 2005, 06:38 PM
Nice Pic of your motor to bad you don't have an all alum oil fill neck for it .That would make it real nice
Aaron Cox
Mar 23 2005, 06:39 PM
QUOTE (ArtechnikA @ Mar 23 2005, 05:33 PM) |
QUOTE (Aaron Cox @ Mar 23 2005, 07:28 PM) | im running my fuel pump off that |
or - use the wire currently attached to your fuel pump to trigger a relay, and draw current for both from that. |
has 2 large wires that go to the battery.....
and a small red wire that goes to a switched + source.....
and then 2 wires to the coil....
will i fry anything that is hooked up to the coil + side tho?
Trekkor
Mar 23 2005, 07:14 PM
You should be able to use the 12+ wire that was the coil wire. The stock coil wire.
That's how MSD does it. I have a wiring diagram.
KT
Aaron Cox
Mar 23 2005, 07:16 PM
QUOTE (trekkor @ Mar 23 2005, 06:14 PM) |
KT |
ok..the remaining wire that went to the + side of the coil is a switched +?
so i could run the hyfire switched + lead, and the dizzy switched + lead off that wire?
Trekkor
Mar 23 2005, 07:25 PM
Find your wiring diagram while I scan mine.
QUOTE |
the remaining wire that went to the + side of the coil is a switched +? |
Yes, that's why if you leave the ignition on, the points/pertronix fry.
QUOTE |
so i could run the hyfire switched + lead, and the dizzy switched + lead off that wire? |
I'd say 95% yes.
stand by...
KT
Aaron Cox
Mar 23 2005, 07:27 PM
QUOTE (trekkor @ Mar 23 2005, 06:25 PM) |
QUOTE | the remaining wire that went to the + side of the coil is a switched +? |
QUOTE | so i could run the hyfire switched + lead, and the dizzy switched + lead off that wire? |
I'd say 95% yes.
stand by...
KT |
ahhh... ok. life is getting much better....
Standing By
Trekkor
Mar 23 2005, 07:36 PM
ear
Aaron Cox
Mar 23 2005, 07:39 PM
sweet....
T dog....
i Oweth you a beer
you ahd to run the diode? you put it behind the gauge?
Trekkor
Mar 23 2005, 07:52 PM
Diode right in-line onto the gen light behind the guage...
Trekkor
Mar 23 2005, 07:54 PM
Oh, and BTW. Only my wife can call me "Sweet T-Dog".
KT
Aaron Cox
Mar 23 2005, 07:55 PM
Mr T...
you rock man
Aaron Cox
Mar 23 2005, 07:56 PM
QUOTE (trekkor @ Mar 23 2005, 06:54 PM) |
KT |
thats not what she calls me....
JK.....
thanks man
Trekkor
Mar 23 2005, 08:07 PM
Careful...
Aaron Cox
Mar 23 2005, 08:13 PM
shoot....
im up against that an at AX!
i concede already!
Trekkor
Mar 23 2005, 08:18 PM
That's right...
This, too.
