sdoolin
Mar 7 2016, 03:49 PM
I'm a ways off yet, but will eventually need an adjustable pushrod to set valvetrain geometry on the 2056 I am building (different thread). I have the chromoly pushrods with ball ends from Type IV Store (Manton) so ideally I'd source an adjustable version from them. But - they no longer have them.
I asked about ordering a single pushrod from Type IV Store (they sell pushrods by the "kit") but I got no love there (which I can understand).
Anyone have an adjustable pushrod fabricated from these parts that they'd be interested in selling (or loaning)?
sdoolin
Mar 7 2016, 04:09 PM
Disregard please - nothing to see here...
Type IV Store confirms they will have re-designed (better) adjustable pushrods available within the timeframe of my build.
DBCooper
Mar 7 2016, 04:27 PM
I personally like www.aircooled.net, here:
http://vwparts.aircooled.net/Adjustable-Pu...ble-pushrod.htm John sorts out the really cheap Chinese stuff so never any drama, but generally any good VW aircooled parts supplier will have them.
Java2570
Mar 7 2016, 05:26 PM
I tried 3 different ones....Aircooled.net's, European Motorworks & Type 4 store.
Aircooled.net, despite the ends being a little different than the ones supplied with the Manton pushrods through Type 4 store, was the only one that was close to being right. The EMW was too long and the ends weren't so good. The Type 4 store unit was too short despite having similar ends (but not exact). Nicole at Type 4 store did say she was working with Manton to get the proper one produced when I sent mine back.
So, your choice, Aircooled or Type 4 store when they get the new ones done.
76-914
Mar 8 2016, 09:00 AM
If you can weld make one from an old rod. I've got a few T4 rods laying around if you need one.
jcd914
Mar 8 2016, 11:03 AM
Since push rods are hollow you should just be able to cut one and tap the inside and get a stud and a couple lock nuts. You'd have to cut squarely and cut out enough to get back to original length but it seems doable to me.
Jim
TheCabinetmaker
Mar 8 2016, 12:25 PM
The problem with the stock pushrod is it might not have the same tip profile as the new ones.
