QUOTE(jcav @ Mar 7 2016, 07:31 PM)
Thanks all i will have to look into that,
For reference the car is a 1975 with the 1.8
The L-Jet system used on the 1.8L does not prime like the D-Jet system does. It also doesn't use any relays or fuses on the relay board.
Disconnect the yellow lead on the starter.
Turn the key to start and listen for the fuel pump.
Second, disconnect the air flow meter from the rubber elbow that connects it to the throttle body.
Turn the key on, and open the air flow meter with your finger.
Both of those should make the pump run.
If it doesn't work, check the yellow wire coming out of the engine harness at the 12 pin connector on the relay board. Make sure it is plugged into one of the two rear spade connectors on the 4 pin connector located in the left rear of the relay board.
If that is OK, check the double relay located under the battery. Make sure both plugs are in solid, and make sure the big red wire is connected to the battery.
If everything is ok there, unplug the fuel pump and put a test light in it's place. Repeat the steps above and see if the light comes on.
