BeemerSteve
Mar 7 2016, 06:34 PM
Hello all,
Without a long discussion on trans oil I know to you use GL-5 but should it be Dino oil only or can you use synthetic as well. Also, someone mentioned to me that add a GM manual trans additive along with the GL-5. Any thoughts will be appreciated.
Thanks everyone!
Steve
Mike Bellis
Mar 7 2016, 07:12 PM
Dino only. Cheapest you can buy will work fine.
Mark Henry
Mar 7 2016, 11:44 PM
Buy it cheap, but change it often is the doctors advice.
r_towle
Mar 7 2016, 11:53 PM
Actually, the factory recommends GL-5 .
I use dyno oil, changed every couple of years because I change stuff...
screenguy914
Mar 8 2016, 03:53 AM
Swepco 201 Multi-Purpose Gear Lube. Ideal for Porsche synchros.
Sherwood
tomrev
Mar 8 2016, 06:32 AM
QUOTE(screenguy914 @ Mar 8 2016, 01:53 AM)
Sherwood
I second the Swepco!
scott_in_nh
Mar 8 2016, 09:31 AM
mine came with fresh Swepco in it, changed to dino and it shifts moderately, but noticeably better
YMMV
'73-914kid
Mar 8 2016, 09:39 AM
My local auto parts stores stopped carrying the good GL-5 with no additives in it.. so I went looking for a good alternative.
The single best semi-attainable gear oil I've used in Kendall NS-MP 80-90. It is specifically designed for Hypoid Gears, which 914 boxes use, and it specifically states that it is for non-Limited Slip differentials. Not even recommended for Top-Offs on LSD.
Most of the stuff you find that is GL-5 and Hypoid Gears has LSD additives. The Kendall has none of that. I put it in the gearbox in my dad's car, and he never crunches even the badly worn 2nd gear synchro anymore.
bretth
Mar 8 2016, 12:01 PM
Anyone know what the shelf life is of gear oil? Have a couple containers of gear oil from about 15 years ago. One was opened and half used. The other is still sealed. Wondering it they absorb water or other junk. Haven't done a manual trans in a while but now I have three that will need new oil soon. Should I scrap the oil or use them?
Brett
914itis
Mar 12 2016, 12:07 PM
I use this one, when cold I crunch gears, after a few minutes of driving shifts smoothly .
wnat is API service ?
pete000
Mar 12 2016, 12:51 PM
I use Swepco, not cheap though!
t collins
Mar 12 2016, 01:28 PM
QUOTE(pete000 @ Mar 12 2016, 11:51 AM)
Mark Henry
Mar 12 2016, 02:59 PM
QUOTE(tomrev @ Mar 8 2016, 07:32 AM)
Sherwood
I used Swepco for several years and I never found anything magical about it. The one thing I did like is with the blue colour it was easy to tell the difference between an engine or tranny leak. I still use almost a quart in each change just for the blue colour, that plus the fact I still have a case left over.
Only gear oil that I thought was an improvement was Kendall.
However I do think Swepco 101 grease is one of the best. I get a case every couple of years.
steuspeed
Mar 12 2016, 03:11 PM
Gear oil fight whoopie
914 Kid has it right. It's hard to find plain old GL5 Hypoid gear oil. I found some CarQuest brand sold by the gallon only. It's super cheap, but it works. You want NON limited slip. Stay away from synthetic and SWEPCO. Makes your trans spin way to fast for old syncros. I tried it in my car and
couldn't get it out fast enough.
Mark Henry
Mar 12 2016, 03:16 PM
QUOTE(steuspeed @ Mar 12 2016, 04:11 PM)
I never had any problem with Swepco...other than the price.
But then way back in the day I didn't have any problem with Slick 50 either.....
Elliot Cannon
Mar 12 2016, 03:27 PM
And don't forget that wonderful Swepco odor.
steuspeed
Mar 12 2016, 03:34 PM
QUOTE(Mark Henry @ Mar 12 2016, 01:16 PM)
You won't really know until you go back. Probably more than one change to get all the Swepco cleaned out. I need to do another change myself. You have multiple cars, so try the worst shifting box you have. I wanted only the best for my car and so I bought the Swepco. It's hard to believe when you spent all that money it's got to be better. For a new modern trans, yes it is. For an old 914, no.
