era vulgaris
Mar 8 2016, 02:03 PM
I'm planning on doing a full tune up this week: plugs, wires, cap, etc etc. Just curious what plug gap I should be running with a 2270 with Mallory Unilite dizzy and MSD 6AL box. Is the stock gap ok for that setup?
michael7810
Mar 8 2016, 05:03 PM
Mike D.
Mar 8 2016, 05:41 PM
I have the exact same set up and have plugs gapped at .050 - I run a little rich across the range and when the plugs come to be checked they look perfect; clean, dry, light tan.
era vulgaris
Mar 8 2016, 07:22 PM
Awesome thanks. Wow that's almost twice the stock gap! Yeah I run a little rich too. I keep my AFR in the high 11's to low 12's. It's where my head temps are happiest.
McMark
Mar 9 2016, 07:54 AM
What coil is Mike running?
What coil is Era running?
falcor75
Mar 9 2016, 07:59 AM
I run 0,8mm/0.032" on a stockish 2.0 with EFI and individual LS coils.
era vulgaris
Mar 9 2016, 08:47 AM
I'm running the MSD Blaster 2 coil
McMark
Mar 9 2016, 08:59 AM
You should be able to get away with a larger gap then. As long as your compression ratio it's insane.
stugray
Mar 9 2016, 09:32 AM
From my notes:
"How much to increase the plug gap when upgrading to capacitive discharge ignition (MSD) 6AL.
As a rule of thumb, it is recommended to increase the plug gap by .005” - .010” followed by testing and tuning.
http://www.msdperformance.com/uploadedFile..._tb_top_ten.pdfA lot of mentions of .045:
http://www.914world.com/bbs2/lofiversion/i...php?t33232.htmlUsing .038 at first"
yeahmag
Mar 9 2016, 06:10 PM
NGK B6ES-11 (pre-gaped)
