Good info guys, thank you.
Yep, in this setup, it'll be EFI. My plumbing idea thus far is actually
tank->
low pressure pump up front->
surge tank up front->low pressure line back through the tunnel->
high pressure external pump on lower firewall->
engine->
return to tank.
That still eliminates the long length of high pressure lines that Mark was alluding to, but also still allows me to stuff a type 4 back into the car if I had to. In this case, the low pressure pump would also be a "lift" pump up to the surge tank, and gravity/pressure within the sump would feed the fuel back to the high pressure pump.
In Chumpcar we don't need a fuel cell if the stock tank is retained, but I sure would like to go the fuel cell route, especially as it would make routing the water lines easier through the front bulkhead. Just need to save my pennies.
Shane, I have not heard of people using the snowmobile pickups, but that's the same concept as the Holley Hydramat (just cheaper). I HAVE heard of a cool one though - some folks use a large Yamaha marine fuel filter which also acts as a surge tank of sorts. Pretty cool idea. I think this is the one I heard them talking about.
