So......after installing the sway bar and new turbo tie rods here are a few lessons learned list at least for me.
1. Get the Weltmeister backing plates and tack weld them in. This eases installation as there is no way you can accurately drill these parts and then compress the bushings to install the caps and bar. This will also keep the bolts from shifting around and tearing the thin wheel well later.
2. Leave the tie rod ends off the rod after installing the new rod into the rack. Slip the bellows over the tie rod and then snap the bellows into the collar on the turbo rod. Take some bearing grease and lightly grease the rack where it is slightly tapered and grab the bellows with both hands, (this is a little tough on the drivers side) and slightly twist and push the bellows until it has landed and slipped onto the rack.
3. Connect the tie rod end to the strut and tighten the nuts with cotter pin. Now move the strut so that it now compresses the bellows. Use the HF "dental pick" set to pull the edge of the bellows into the groove on the rack. Take spring holder that you should have just moved near the center of the rack from the old bellow and take the pick and pull in into the corresponding groove on the bellows to the rack.
4. Lastly...check your "fing" ball joints carefully. I thought I didn't have to replace mine but the passenger side is shot. See pics. and a question from various searches:
Leave the castellated nut on the ball joint and try and remove the tapered pin first?
I have banged on the freekin pin and it will not budge. Frustrated as I was ready to put everything back together today and no sense not replacing it. It looks to be original.
Some pics.
Bad ball joint
