QUOTE(gunn1 @ Mar 10 2016, 03:41 AM)
Mobil 1 synthetic grease....is it ok to use on wheel bearings?
depends on the grease thats in there now!if its soap, waxed based or lithium complex your gonna have a problem down the road, there not compatable ...completely clean old grease away clean with hot soapy water dont use a degreaser or brake cleaner... i posted a compatability chart on here a few years back
if they are new you still have to clean the factory oil off them with hot soapy water,because more then likely it to is not compatable with synthetics lubes
good luck
