914Sixer
Mar 10 2016, 12:35 PM
Getting ready to build the 2056. I got my camshaft done at Elgin Cams and went with Demas recommendation of the 330-1 camshaft. Supposed to add a little extra with the bump up to 2056 with stock fuel injection. Profile looks similar to Web 73.
Anybody running one?
pilothyer
Mar 10 2016, 05:43 PM
Mark....Just about anyone running the 9550 or 9590 is running one :>}
jcd914
Mar 10 2016, 06:53 PM
I'm running (well if the car was back together) an Elgin cam.
I have no idea what Elgin's number for this is but he cam works very well well.
This cam has same duration and lift as early 914 cams but has steeper ramps so it opens and closes valves a little faster, engine breathes a little better.
If it were me I would take Demas advice.
Jim
914Sixer
Mar 10 2016, 08:37 PM
Yes, your cam sounds like the one I got from Dema Elgin. Waiting on the Factory NOS stock lifters to come in to get started. Should be a fine running engine with the parts I have coming.
lonewolfe
Mar 11 2016, 06:29 AM
QUOTE(914Sixer @ Mar 10 2016, 06:37 PM)
I also have an Elgin cam for a 2258cc motor in the works. I think mine was an 8001 or something like that. I'm running Dellorto carbs for this street motor.
914-Sixer where did you find NOS VW lifters?
914Sixer
Mar 11 2016, 06:59 AM
I found the NOS lifters in Canada. Bought the last set he had.
lonewolfe
Mar 11 2016, 07:20 AM
QUOTE(914Sixer @ Mar 11 2016, 04:59 AM)
Nice find. Dema recommended new stock lifters. He didn't know where to get them. I've not been able to find any do I ended up buying a parkerised set from Type4store.com.
anderssj
Mar 11 2016, 12:17 PM
I've been running an Elgin 7008-4 in my modified 2L since 1982. Engine has ~ stock displacement with Mahle euro PC set and dual DRLA 40s. IIRC, the cam is 280* duration (net intake lift = .420 @ cold .006 lash, net exhaust lift = .403 @ cold .008 lash). It's been great! I think Bayside in Redmond WA built at least one similar motor using the same cam in the mid- to late 1980s.
lonewolfe
Mar 12 2016, 07:54 PM
I just checked my Elgin cam and it's a 7008. It's for a 2258cc 96x78 street engine run with Dellorto DRLA 40's.
