lcjo73914
Mar 11 2016, 11:59 AM
Anybody knows any thread of 914 running on either Porsches 944 0r Porsche 928 engine?
Thank you
ClayPerrine
Mar 11 2016, 12:07 PM
QUOTE(lcjo73914 @ Mar 11 2016, 11:59 AM)
Thank you
There is a 914 on here with a 928 motor. Look up "The Alien" in the search.
Mar 11 2016, 12:17 PM
QUOTE(ClayPerrine @ Mar 11 2016, 10:07 AM)
As far as conversions go, the 928 motor is probably one of the hardest to do ...
Mark Henry
Mar 11 2016, 12:59 PM
QUOTE(SirAndy @ Mar 11 2016, 01:17 PM)
And the 944 is just as long isn't it? Therefore just as hard.
Dave_Darling
Mar 11 2016, 02:00 PM
That's my understanding as well, which is why we have zero 944 engine conversions in 914s. For the same amount of work, you can have twice as much motor... Or for less, you can put an SBC in, as those are shorter and fit more easily.
--DD
Mikey914
Mar 11 2016, 02:07 PM
Subie and L6 seem like the best conversions I've seen There is plenty of guys doing them. You may do better to use a more common conversion to make the project easier. Besides I'd hate to have to adjust the tension belts in the car on either of those motors.
porschetub
Mar 12 2016, 11:57 AM
QUOTE(Mark Henry @ Mar 12 2016, 07:59 AM)
I think so also,having owned 2 944's IMO they are one of the longest 4 cylinder motors I have seen.
Mueller
Mar 12 2016, 12:42 PM
No kits, you are 100% on your own, if you cannot do 99% of the work good luck finding a shop that won't drain your bank account doing it for you.
Like mentioned the motors are super long, more so at the top where space is more limited on a 914.
The 944 motor is basically half a 928 engine so no advantage of going with that one. Even if the motor was free I don't think I want to tackle such a project. I think the 90° 3.6 V6 motor would be a sweet engine and would fit way easier.
lcjo73914
Mar 12 2016, 02:56 PM
Thank you all for the advice.
I will work with H6 conversion.
again thanks
steuspeed
Mar 12 2016, 04:02 PM
Or you could just buy a conversion. Plenty out there. Probably save a lot of $$$ even if you still wanted to make changes.
r_towle
Mar 12 2016, 04:10 PM
QUOTE(Mueller @ Mar 12 2016, 01:42 PM)
baloney
