Aaron,
Try not to use MAACO if you can help it - both their work & pint sucks - Sheerwin Williams low grade. Delphi is metallic - ergo multi-coat application, so more expensive than just a single coat non-metallic (except black). The keep their prices down by doing it quickly & half-fast! Then their paints don't last - the `06 Maaco job on my 85 BMW 325e is peeling at the roof already, & it's a half-fast super wafer thin coat peeling off to boot!!
If you have to use them of !-Day, Sheib, & the other hacks, then plan to do all of the body work, skim coating & block sanding for the prep (everything shows on a metallic paint job & black), then also do all the masking yourself, since they'll do a crappy job anyway, & you'll have all sorts of overspray to clean up.
The wrap may not be a bad idea, & you could do clear if the current paint hasn't failed yet to where it's oxidizing or peeling, but I think it may go a bit more than $350 in SoCal.
I think that $3-5k is the going rate for most reputable shops using quality PPG or Dupont paint around SoCal, & many won't want you to do the prep, unless you waive the warranty & any flaws left by you in the prep - & maybe still won't want to have it go out with their name on the job over which they had no control over the major part of prep.
I can give you my guy in Huntington Beach & he can do a DD level job with PPG - non-color change, but I don't know how much, & my guess is in the $3-5k range. Just shoot me a PM or email.
Good Luck!
Tom
