Starting to assemble my 2056. I'm installing Mahle main bearings. My first concern is the center main (split). Even after tapping the center with a block of wood and a hammer to seat it, the edges protrude about .010" on both case halves. Is this normal? Are they designed like that so they "draw down" when the case halves are torqued together?
The other thing I wanted to check on is the Kolbenschmidt cam bearings. I compared the size to the original bearings and found that the set for the center cam journal is .190 narrower than stock. Is this just how they make them now?
Thanks!
