I'm having fun testing all the components before the final install on my 1970 1.7 L.
Tested my three port fuel pump to see how it ran and decided to post results, Will see if 914 world allows short videos but here are the stills:
Original configuration was mounted in the engine compartment.
Here's the hoses after hacking them off:
Make sure the positive and negative are correct. The plug will help you but just for clarification the positive terminal is on the right in this picture. The negative terminal is on the left.
Put fuel filter between gas tank and 'S" ALWAYS. Pay attention to filter flow direction.Click to view attachment
Iv'e labeled the hoses here: It's not hard: The outside port is Supply (from gas tank).
The middle port is the Druck or Pressure port.
The inside port closet to the electrical plug is the Return line.
Think about it like this:
The gas tank Supplies gas to the fuel pump to the S port.
The fuel pump pressurizes the system and sends pressurized (Druck) fuel through the tunnel to the fuel rail on the right side (injectors 3&4) of the engine and then passes through the cold start valve injector (sometimes called the 5th injector) and then to the left side of fuel rail (injectors 1&2) then through the fuel pressure regulator.The line returns back through the tunnel to the "Y" junction tee.
The "return" fuel splits at the "Y" junction where a portion returns the fuel back to the fuel pump to remain pressurized and partly back to the fuel tank.
I replaced the brittle plastic lines with stainless lines from Chris at Tangerine Racing and ditched the 46 year old plastic T for a brass one. If you are going this far, replace that crudded up old filter in the bottom of the tank on the 10mm fitting.
I mixed about 1 ounce of fuel injector/carbuerator cleaner in 1.5 gallon of clean gas and ran the pump for a few minutes to make sure the old smelly gas was completely out.
The 46 year old Bosch fuel pump fired up immediately, purred like a happy kitten !!!
What a treat !
