74914LE
Mar 13 2016, 09:21 PM
Is it possible to replace the qty. 19 Windshield Molding Clips, with the Windshield installed in the car?
Finally to the point of installing the Molding, after getting the
car painted, and several are going to need to be replaced in order to get the trim to
stay in place. The previous owner used silicone glue to strengthen the clips, and
it is time to fix it correctly this time around....opinions??
Thanks!
dangrouche
Mar 13 2016, 10:37 PM
You might have clearance problem. There is a platic center stud that needs to be pressed in at the center of the clip. The clips are usually installed with no glass in place.
Here's the thread
http://www.914world.com/bbs2/index.php?showtopic=74816
falcor75
Mar 13 2016, 11:14 PM
No the glass needs to come out.
jkb944t
Mar 14 2016, 05:56 AM
QUOTE(falcor75 @ Mar 13 2016, 09:14 PM)
This advice couldn’t have come at a better time since I am ready to install a new windshield and didn’t realize that the clips need installed before the windshield.
Thanks!
Jeff B
74914LE
Mar 14 2016, 06:12 AM
Thank you. I was afraid that would be the case.
cary
Mar 14 2016, 09:52 AM
I'll shoot a picture today and post tonight. I think are three around here without glass.
cary
Mar 14 2016, 09:33 PM
Forgot to shoot the shot.
Here's what I have. The little black pin in the yellow circle is the pin/rivet that the clip mounts to, as you can see it would be under the glass.
