Hey everyone,
So I put the car up on jackstands and started pulling things apart to check for rust. I pulled off the rocker panels and low and behold.. The pictures I've included are of the passenger side (of course). My question is, would this require a complete longitudinal replacement? I'm not trying to just patch the car together, I ask because there's really no rust around that area. Of course I do not know unless I really start pulling off panels, but there's none on the floor board under the carpet, none on the underside of the car. I've poked around with a screwdriver and haven't found any weak areas around the existing holes. Do you think I could clean the areas up and have patches welded in? There's no body flex. I'm 6' 7 285 lbs and can sit in the car with the top off open the door, wind up the window and it shuts fine. I don't know, what do you think? Honestly, I just want to drive it!
