So it came as a surprise that my car has 12mm plugs. I thought all 914's had 14mm?
The PO was using NGK DP8EA-9. Looks like they have a pretty high heat rating at 8. The 14mm plugs most people seem to recommend, and that I used on my old 1.7 are the NGK BP6ES, which have a heat rating of 6.
Should I be looking for a similar rated plug for my current car? It's a 2270 with Mallory Unilite dizzy, MSD 6AL, and MSD Blaster 2 coil. Is there a better plug for my setup than the DP8EA-9?
