QUOTE(McMark @ Mar 15 2016, 10:31 AM)
It's more work than you need to do, but it's a good project. Replace all the bulbs, making sure they're correct. The wattage for each bulb is embossed into the housing. Most are 21w or 5w. Most people use 1156/1157 bulbs which are very common, but the 1156 is 27w and the 1157 is 27w/8w. These are not correct, which 'confuses' the flasher unit, AND is the cause of most of the melted housings you see. They are brighter, but brighter is hotter. The housing isn't meant for those bulbs.
Also, clean the bulb holders to remove corrosion, as well as the connections (just plug/unplug them a few times).
I'm sure glad to see you posting again, Mark.
Must be thawing out there and your ready to come out of Hibernation. Don't make the mistake of swimming in one of those ponds April-May. There colder than a Well Digger's Ass in January. I don't believe they ever warm up. Anyway, good to hear an authoritative voice again. The Cap'n left the building and we need your input.
Kent
