The directions say to" disconnect the ignition/starter witch wire (usually a red wire with a black stripe from the start connector of the starter solenoid, and attach it to the blue wire of the relay."
So is that the red wire in the yellow sheathing that is attached to the solenoid? Wondering because the blue wire on the the relay has a spade connector, and the wire going to the solenoid has a round "hole" connector. I'm thinking my setup is not normal.
Also, it says to "attach the black wire of the relay (terminal #87)to the start connector of the starter solenoid." That connector is currently occupied by the yellow wire in the pic. Do I just disconnect that and tape it off?
TIAClick to view attachment
