Mikey914
Mar 14 2016, 06:26 PM
This is a 75 2.0 motor that was in my son's car, he had no heat, so I'm having Cary do some sheet metal work and I'm trying to get it all back together.
I need some heat exchangers as these have seen better days. They appear to be 1.8 as they have the triangle flange to mount the exhaust.
I also need the sheet metal in the diagram below as it's missing.
Mar 14 2016, 06:51 PM
If the "sheet metal" from a 1.7 -'71 will fit, I have you covered. No charge, I have plenty of this stuff.
I have a muffler hanger to fit the early exchangers.
I don't have heat exchangers though.
boxstr
Mar 14 2016, 06:58 PM
Mark, I will look at CAMP 914 tomorrow, I have some of what you need.
Also, look at the text I sent for that steering shaft piece.
Craig at CAMP
bdstone914
Mar 14 2016, 10:37 PM
If you don't get the heater tin from Mark let me know as I have it too. I might have one 1974 1.8 heat exchanger. They have the same pipe size as the 2.0L One year only part. You will also need early warm air guides and warn air elbows in addition to the circled parts in the image. Those are stock heater boxes for 75-76 1.8 and 2.0L.
Tom_T
Mar 15 2016, 02:02 AM
Mark,
You can just put the bigger pipes 2.0 HEs & muffler on the 1.8, & it'll breathe better & make a bit more HP/TQ than stock. Even in CA that 75 would still be smog exempt without the 1.8 HE & Crapalytic Converter (on CA cars only). IIRC all the heat tubes & pipes are essentially the same on both 1.8 & 2.0 as circled in red on your parts diagram.
Just sayin'!
Good Luck!
Tom
Mar 15 2016, 05:28 AM
QUOTE(Tom_T @ Mar 15 2016, 04:02 AM)
Mark,
Just sayin'!
Good Luck!
Tom
When he uses SS 1.7/1,8 heat exchangers they will have the same inside diameter as the 2.0 but cost less.
rhodyguy
Mar 15 2016, 08:17 AM
Dependent on the heat exchangers you decide on, Dave Ellison might be able to retro fit the Triad with the correct heat exchanger to muffler flanges.
malcolm2
Mar 15 2016, 10:25 AM
aren't the triangle flanges an indicator of age vs. engine size. So 75-76 had the triangle and the short exhaust "header" pipe? Not shown in your diagram. I would say the daig. is a 74 and older.
Mikey914
Mar 15 2016, 10:30 AM
Thanks Guys, I do have a lead on the 75 1.8 bits. Just waiting to see some pics, hopefully it will have most of what I need.
This is for my RUSToration that Cary is doing for me. So, yes we can easilly fabricate what we need, but 1st choice it to get what fits.
I love the Triad, and will be keeping it on.
Mark
