Amphicar770
Mar 14 2016, 10:40 PM
I took lots of photos but wish I had taken better notes in terms of the order in which I removed things. Now I am starting to worry (perhaps needlessly) about reassembly.
Any advise on sequence of reinstalling tins, fan, flywheel, alternator, etc.? Trying to avoid having to redo things because I did not put part A on before part B.
TheCabinetmaker
Mar 15 2016, 05:32 AM
Start with the piece between the oil cooler, and#4 cylinder. Then the one between the alternator and # 2 cyl. There are also the two that go above the pushrod tubes. Next, the alt front tin. Next would be the upper cylinder covers and the rear lower with the rear. Last is the front of shroud.
