Hello; Went to look at a 914 today. A 1974. A few issues to be sure and I am wondering what I may be getting into.
First there is rust, but not as much as on some others cars I have looked at. The rust is a crap shoot but that is not the question.
The fuel injection has been thrown out and replaced with a single carb. I was lucky enough to see the car at the mechanics shop. The carb is a two barrell and has a geared linkage between the primary and secondary barrells. This is supposed to prevent the flat spot common to such a setup. The car did start well hot and did not seem to bog as the engine revved. There are also two webbers with the car.
My question is about the possibility of getting a fuel injection system and making it work? Any comments welcome.
The next question is about the lack of heat. The exaust is only the pipes with no heat exchangers at all. I think much of the rest of the interior heat system parts are gone also. Any comments welcome. I want heat.
last is that the engine cover lid hinge is broken on one side.
While I did not get to drive the car, the owner took me for a ride. The trans worked fine with no grinding.
Any comments welcome. Thanks in advance.
