914itis
Mar 16 2016, 11:44 AM
Where can I get the bung that welds to the muffler for the air fuel ?
How many do I need and what is the preferred location.?
TIA
Andyrew
Mar 16 2016, 11:50 AM
You can get them from Ebay or pretty much anywhere, its just an O2 sensor bung.
You should only need one for total AFR, but it depends on what exactly your doing and how accurate you want it. If you have carbs and you want it really accurate then one per side would be more than you need.
In reality one is fine and anywhere in line SHOULD work. If you have a collector I would put it about 6" after the collector.
Luke M
Mar 16 2016, 11:52 AM
QUOTE(914itis @ Mar 16 2016, 10:44 AM)
TIA
Jegs or Summit should have the weld on bungs.
Is this for your 6 or 4 cyl engine?
colingreene
Mar 16 2016, 12:03 PM
vibrant, or even LUL Frozen Boost.
914itis
Mar 16 2016, 12:47 PM
Thanks Andrew
Like - yes it is for the six
TheCabinetmaker
Mar 16 2016, 01:28 PM
I get mine at a local speed shop. Do they have those in nyc?
stugray
Mar 16 2016, 01:57 PM
tomrev
Mar 16 2016, 02:02 PM
I have recently found them on ebay shipped for around $6.
Mark Henry
Mar 16 2016, 02:48 PM
Carquest...almost any FLAPS
Actually you can use a nut with a 18 mm X 1.5 thread pitch.
914itis
Mar 16 2016, 03:27 PM
Thanks all found them at my local flaps . $4.00 for a pair .
stugray
Mar 16 2016, 04:21 PM
QUOTE(914itis @ Mar 16 2016, 03:27 PM)
Oh, so you finally "got a pair"?
Sorry, couldnt resist
76-914
Mar 16 2016, 04:24 PM
Locate that bung between 10 & 2 O'clock. Es muy importante. Did you buy a steel or SS bung?
914itis
Mar 19 2016, 07:39 PM
I installed 2, I want to be able to monitor both carbs .
Is there a dual kit out there ot do I have to purchase 2 kits?
Can someone point me out to a good one .
Thanks
76-914
Mar 19 2016, 07:41 PM
There ain't much difference in any of them other than the material. If you have SS exhaust you might want to order SS bungs. No, you need to order 2 individual bungs AFAIK. Ebay, Summitt and all the usual suspects
914itis
Mar 19 2016, 08:10 PM
QUOTE(76-914 @ Mar 19 2016, 09:41 PM)
Thanks
