Hi, all! I'm downsizing my 914 hoard, and I was curious if anyone had any need for this stuff before it goes away. I hate to toss it if someone needs it, so PLEASE make an offer. I promise that I won't be offended. I only list the prices because we're supposed to. Please note that all electrics are untested and all items are understood to be driver quality. The transmission was good when it was removed. If you have any questions, please shoot me a PM/E-mail/reply. I'll reply as soon as I am able. Payment via PayPal, shipping extra. Thanks for looking!
1 Key Blank $20
2 Heater Control Knob $5
3 HVAC Bezel $5
5 Voltage Regulators $5 each
6 Hub Covers $10 each
7 Rear Trunk Lock Spring $10
8 Fuel Lines $5 each
9 2.0 Plenum Brackets $5 for the pair
10 Fuel Injector Supports $5 each
11 2.0 Cold Start Valve Connectors $5 each
12 Belt Cover $5 each
13 2.0 Plenum $40
14 2.0 Fuel Intake Runners $20 per set
15 Starter $10
16 Alternator $25
18 Driver's Side Engine Shroud $150 for all tin
19 Various Engine Shrouds $15 per piece
21 Ignition Coils $10 each
22 Impeller Fan $50
23 More Engine Shrouds $15 per piece
24 Impeller Fan Shround $30
25 Smog Pump Pipe $20
26 Heater Pipe $15
27 Passenger Side Engine Shroud $150 for all tin
28 Defroster Vent $10
29 Leather Steering Wheel Cover $15
30 Side-Shift Transmission $150
31 Headlight Brackets $10
32 Headlight $10
33 Defroster Vent $10
34 Headlight Covers $10
35 Ashtray $15
36 Windshield Wiper Motors $10 each
38 Fuse Panel Board $10
39 Wiper/Turn Signal Stalks $5
40 Headlight Cowl $15
42 Fresh Air Vent Cover $5
43 Non-Fog Light Grille $40
46 Factory Radio $180
48 Chrome Trim $5 per piece
49 Rocker Arm Spacers $5 each
50 Windshield Wipers $5 each
51 Fresh Air Deflector $5
52 Rear View Mirror Base $5
53 Rubber Shift Boot $5
55 Turn Signal Bracket $5
56 Door Handle Bezel $10
57 Pedal Covers $5 each
58 Electric Fuel Pump $10
59 Window Crank $5
60 Trunk Bracket $5
61 Cigarette Lighter $10 (no element)
62 Seat Belt Light $5
63 Trunk Light $10
64 Steelie Lug Bolts $30 for the set
65 HVAC Cables $5 for the set
Let's try this link: https://flic.kr/s/aHskwmzgof
