Got a chance to do some more patching of the '14 today.
Here is a pic of the front trunk after I removed all the bondo some time ago.
At the time I got really scared and never thought I could fix it.
Thanks to the helpful pictures and encouragement here, I am tackling this like a pro!
Now the channel on the left of the part I cut out looked OK and you can see where I POR15'd some of it when I did the front fender.
But then I noticed there seemed to be some rust forming between the metal parts and decided to investigate.
You can see that the POR15 hasn't penetrated, although it adhered really well to the exposed metal.
This is what it looks like now.
I am not planning on using the factory seal - I will make something else fit.
The question is why do I need to add the "lip" on the front?
Would leaving it off mean that water ran away from there and helps prevent the rust coming back?
Thoughts appreciated.
Cheers
GAZ
