80cap
Mar 19 2016, 10:14 AM
Where to buy new turn signal and wiper switches? What vendor has the best bang for the buck? I already bought used and that did not work out. I don't want to tear them out again.
Thanks Brian
forrestkhaag
Mar 19 2016, 12:35 PM
Try VW parts outlets on the net / the switches are sometimes identical save he little number stamped on the case of the switch....
914Sixer
Mar 20 2016, 07:24 AM
72-76 Turn Signal switches are the same as the VW part. The 75-76 Wiper Switch is NOT a standard switch. The steering column was sourced from the VW Rabbit. Switch has extra clearance of the back side the early one does not.
I switched my whole column out to 74 and used the late ignition switch with the early electrical portion
