QUOTE(914_teener @ Mar 20 2016, 01:02 AM)
There is no reason not to take the trailing arm off. It's not that much work.
While it's not necessary to take off the trailing arms, it is a hell of a lot easier to install the bearings with the trailing arm on the bench.
To install the hub, I made a puller with a very large diameter all-thread and some equivalent washers. I welded 3 washers together so they wouldn't bend.
To install the bearing, I froze the bearing and heated the trailing arm with a heat gun. When I installed the bearing, it dropped right in place.
Then I froze the hub and heated the bearing and trailing arm with the heat gun.
Using the all-thread, I put the hub on the bearing and pulled it in. Very easy.
BTW, it is possible to get the trailing arm off without disconnecting the axle from the transmission.
