ctkellett
Mar 20 2016, 02:25 PM
So, I am out of tricks. Any suggestions? The lower shock bolt that goes through the control arm is stuck. Heat, soaking, hitting, prying...... no luck.
Thanks!
Shadowfax
Mar 20 2016, 02:37 PM
Try using a floor or bottle jack to raise the control arm slightly and the bolt should slide out easily.
ctkellett
Mar 20 2016, 08:13 PM
Thanks Shadowbox, I have not had much like with that method either. These lower bolts are not threaded in the control arm, right? Just at the end of the bolt.
toolguy
Mar 20 2016, 08:24 PM
correct. . not threaded but a very tight fit. . could be rusted in the swing arm and shock bushing. .
the end has slots on each side. . have you tried a big wrench to turn it both ways??
Or a giant C Clamp to push it through?
