jgiroux67
Mar 25 2005, 06:54 PM
Im changing the ride hieght and in order to do so I need to take the torsion bar cap off. This thing is stuck on their good. Any advice in getting it off?
skline
Mar 25 2005, 06:56 PM
Why do you have to remove it to change the ride height? I never had to do that. They do come off but its not easy. I popped mine off from the inside. With the torsion bar out, you just pop it off from the inside.
jgiroux67
Mar 25 2005, 06:58 PM
I have to index? reindex?, whatever its called i need to do that. The car is sitting way to high and the adjuster screw is all the way lowered.
SLITS
Mar 25 2005, 07:02 PM
Are you sure the ass end isn't sitting to low from weak springs?
Any way, with the tension off (car jacked up) and tension released (adjuster screw all the way out), it should come off reasonably easily. If not, try a pry bar to pop it off the end. The torsion bar will not come with it.
TimT
Mar 25 2005, 07:05 PM
drill a 1/4 or so hole near the edge of the cover, and pry it out
Rhodes71/914
Mar 25 2005, 08:09 PM
I just did this and had to use a pry-bar.
QUOTE |
The torsion bar will not come with it. |
Mine did which I was concerned about, but it seems to be ok.
jgiroux67
Mar 25 2005, 08:10 PM
Found out what my problem was, I has pressure on the A arms. A soon as a took the pressure off the caps came off with the greatest of ease. I lowered my car probably 2 inches. I couldnt be happier
