Both Optima & Odyssey & Interstate & maybe some other
sealed AGM & dry cell lead-acid, Li, etc. would work & preserve the rust-abillity nature of our 914s a bit better than .
Optima Red top is for cars, yellow top is deep cycle for RVs & campers which don't get used often, drain down 90-100% & then need full recharging often.
Some folks like yellow top for that reason if they occasionally drive their 914s/cars .... or guys like SoCalAndy who has
everything YELLOW in his 914s!
Note that the new batteries today made by both Optima & Interstate are NOT what the folks above with older batteries were, as they lowered their excellent 8+/- year warranty down to just 2 years a few years ago, with quality lowered as well, after they were both bought out & production moved to .....
wait for it ..... China!
They're still good batteries, but today you're getting 1/4-1/3 the life, quality & warranty for a very expensive battery, as compared to their originals, IMHO.
I've used their sister Interstate sealed batteries in my `85 BMW 325e E30 with the rear battery in the trunk & requiring more CCA due to the long run to the front engine, & conversely in my `88 Westy under the front seat & conversely long run to the rear engine with good luck for 20+ years, with most lasting 7-10 years.
IIRC they also have a flat-plate AGM version too, so you could use either that or Optima - with the caveat of the new shorter warranty & less quality.
Some folks also like the Exide AGM as well, which may be less costly for you up in Canada.
BTW - I'd still recco an acid neutralizer pad under any battery in a pre-zinc-treated car body.
FYI - Porsche didn't start hot-dip zinc treatment until `76 MY - EXCEPT for 914s, which 76 MY 914s were all built in 1975 & sold as 76 MY thereafter.
PS - my nefarious & as yet untried plan for my 73 2L's resto, is to mount a smaller but same CCA/V/etc. capacity Oddyssey lead-acid dry cell or another Li etc. battery inside a "blank case" for an old school Bosch battery as a "case" - so it looks OE, but runs as new tech - with the added security of the battery case serving as a battery tray/enclosure, such as those used for inside trailer battery installations to contain any leakage.
Good Luck!
Tom
