QUOTE(Valy @ Mar 26 2016, 07:45 PM)
BTW, when welding Zinc, galvanized metal or whatever has Zinc, always use a closed respiratory system. The gases released are fatal.
If you are talking about metal fume fever which comes from welding it is not fatal. You usually feel like crap for 1-2 days as the symptoms subside. Drinking milk helps lessen the effects. Look it up on the web for more than you want to read but it is
not considered fatal.As with any welding, painting, grinding, etc. breathing of the fumes in the long term is probably not the best for you. Limited exposure is the best solution.
