Gearup
Mar 27 2016, 01:46 PM
Gentleman. Curious if a remanded Bosch 914 starter will work with my 283 v8 (<10:1 compression) engine. Or, do I need to shell out for a heavy duty starter? If so, any recommendations appreciated as to best bang for the buck. Happy Easter BTW. Thanks, Brett
tomrev
Mar 27 2016, 02:31 PM
I'd plan on getting one of the gear reduction starters; I have used them on both 283, and 383 914's, without any problems. Renegade, or ebay versions.
Bruce Hinds
Mar 27 2016, 02:59 PM
The short answer to the question is a probable yes. My 327 had 9:1 and worked well with a hot battery for several years until the starter started jumping teeth on the flywheel.
It's not so much the power of the starter but the bearing doesn't like that compression bump and will eventually wear. After replacing the ring gear on the flywheel I shelled out the bucks for the reverse rotation chevy starter from Kennedy.
Gearup
Mar 29 2016, 11:47 PM
QUOTE(Bruce Hinds @ Mar 27 2016, 12:59 PM)
Thanks Gents...
