914Sixer
Mar 27 2016, 04:37 PM
Now I know why the replacement seals are not working out properly. They are not made the same way as the factory seal. I have read threads about them not seating properly and going too deep. I made a buy on some NOS German seals. Side by side they are totally different and in the way the seal up. Replacements have no flanges on them to seat in the transmission housing. The NOS ones are the right depth and have a flange.
First set of pictures is side by side. Second set is the replacement seal in trans and then showing reversed OEM on the shaft so you can see the flange. Third set shows the OEM seal in place vs the replacement.
914Sixer
Mar 28 2016, 01:15 PM
Hope this sheds some light on things.
Highland
Mar 29 2016, 12:01 PM
Can this seal be installed with the transmission assembled (Input shaft in place but tube removed)?
My old seal is already out, so removal is not an issue.
914Sixer
Mar 29 2016, 03:20 PM
Lube up the new one and tap it in. That's all there is.
bretth
Mar 29 2016, 03:40 PM
Unless i am missing something it looks like the replacement seal has two sealing surfaces compared to the factory part's single seal but, no flange to make install easier?
Brett
Highland
Mar 29 2016, 05:23 PM
So the answer is Yes. The seal can be installed with the gear stack and input shaft in place.
