QUOTE(bdstone914 @ Mar 30 2016, 10:38 AM)
6 pin, had one with the same number sitting here. Correct for a 1974 1.8L 914 only.
Good price if it works. Should pop the cap off and inspect the circuit board for wear.
Bruce
I just checked my the other day at the pins and had the correct readings but I had no idea that a visual inspection should be done.
May be obvious to most folks here but what am I looking for in the inspection you describe.
Thanks.
