QUOTE(jack20 @ Mar 29 2016, 02:10 PM)
Hi,
Can someone explain how to remove the e brake cables from the trailing arms?
Thanks in advance.
Jack
So you have disconnected it from the caliper? removed the clip, remove the pin. Might have to add slack from the handle side or at the adjuster nut at the firewall tube. It should pull thru the hole in the trailing arm once it is all disconnected?
