QUOTE(Eric_Shea @ Mar 29 2016, 04:47 PM)
I don't have a proportioning valve (or an equalizer) in any of my 914's either. In fact, none of us do. It's a pressure regulator. If you can't lock up your rear brakes, you may want to rebuild them, put good pads in them and adjust them. Then, when they kick in on a curve, with a deer in front of you, you'll at least know "why" you spun off the road.
A pressure regulator acts like a T-fitting until you get 525PSI on the system. Then it temporarily prevents fluid from going to the rears. It's the first anti-lock brake device. It was installed by Porsche on purpose. "Anything" in a mid-engine'd car to prevent you from polar moment inertia induced spin is not something that belongs on a desk holding down papers. That's what A-Calipers are for.
That said... ders a lots of guyz out der dat are smartr den me.
Actually what I have found is that the aftermarket "Brake Proportioning Valves" like the one sold by tilton:
https://tiltonracing.com/wp-content/uploads...oning-Valve.pdfare advertised to work exactly like the stock "regulator".
Here is a plot of the stock regulator output pressure:
Here is a graph of the behavior of the tilton in the various lever positions:
You can see that they are identical except with the adjustable valve you can "move up" the transition point to a higher value.
In position 7, you essentially have a "tee".
In position 3 you would be close to the same as the stock valve in a 914-6 @500 PSI
And position 4 for a 914-4 @650 PSI
