QUOTE(ClayPerrine @ Mar 30 2016, 08:31 PM)
QUOTE(pilothyer @ Mar 30 2016, 08:28 PM)
I know it may be too late now, but after disconnecting the cable threaded end from the front clevis, cut off about 1/4 inch from the threads on the front of the cable for easier removal from the tube.(better yet cut the whole end off) You may also need to cut about 1/4 inch from the front threaded end of the new cable for easier insertion.................you won't miss 1/4 inch at all, but it will go in much easier.
Why??
30 years of owning and working on 914s and I have never heard this.
How could 1/4 inch make the cable easier to insert or remove?
I don't know why, but after 40 years of replacing clutch cables, I have found this to be true.............especially in the last 10 years. I have had old cables get stuck upon removal and I have had new cables get stuck when trying to inset them after only about 1 foot or so was inserted. I would cut about 1/4 inch off the threads and it would always go right in..............Not trying to add drama to a simple clutch cable replacement, but simply reporting what I have found..........I am sure I am not the only one to ever have a problem in this area.
