8 days later, she fired up again - no leaks this time.
It started snowing as I was setting the timing...but I couldn't resist taking her out for a 20 mile test drive. Everything seems to be in order.
https://www.youtube.com/watch?v=7m6raOCZXQ0...eature=youtu.beI wanted to follow up on this thread to show my findings and possibly save someone some grief down the road.
I'm not sure if the rear main failed on startup or if the flywheel itself was bad...or some combination of the two.
Ran the car for 20 minutes with after adding fluorescent dye to the crankcase...this is how much oil I lost:
Click to view attachmentPulled the transmission out. Didn't need the fluorescent dye to see where it was leaking from, but it did look cool under the UV light.
Click to view attachmentClick to view attachmentInspected the flywheel sealing surface. There was some pitting where the rear main seal rides all the way around:
Click to view attachmentTook it back to the machine shop and they swapped it out with another one. I went around the sealing edge of the flywheel with some fine scotch brite until it looked like this:
Click to view attachmentReset end-play. This task was a lot easier with the engine on a stand:
Click to view attachment Installed a new SABO rear main seal with a little oil on the sealing edge. Fired it up and kept my fingers crossed. No leaks!
I'm not convinced the rear main was the problem in this case. But I'll be using SABO rear mains on future rebuilds to avoid any potential headaches. Additionally, I'll be sure to carefully inspect the flywheel sealing surface.
Thanks to 914world for the education on the rear main seals...much appreciated!
