Hello fellow Michigander and welcome to the club <!-- emo&:trophy: -->
<!-- endemo -->
Fear not... your worst problem with be getting the inner adjuster covers off. Here's the scoop:
1. Remove your parking brake cables. (In Michigan, they're probably fused together with ferrous oxide.) Remove the clips and the pins.
2. Remove the outer adjuster covers and then the inner adjuster covers. These take a 13mm open end wrench for the outer covers (if they're still there, most aren't) and a 4mm hex wrench for the inner cover. You'll want a socket set with a long arm and the hex bit. 80% of the time the inner adjuster cover will be stuck and hence will strip (simply not enough hex surface area to overcome the rusted engaged thread). If this is the cae, your now in for a dime in for a dollar. Take the caliper off. Take a Dremel with a cutoff wheel and cut a groove in the cover (order a new 10mm cover and copper gasket now... even if you get yours off, you won't the next time.) Once you've grooved the cover take a chisel and hammer and whack it until it turns. Hey... now your ready to begin adjusting!! <!-- emo&:D -->
<!-- endemo -->
3. If you had to take them off, put them back on. Turn the inner adjuster "CLOCKWISE" to force the piston in toward the rotor. Do this until you have a .008 clearance.
4. The outer adjuster has a 13mm lock nut holding it in place. Loosen the nut but don't force it too far out. It has a lock clip on the shaft that will stop it from going too far. Now turn the outer adjuster "COUNTER CLOCKWISE" to force the piston toward the rotor. Same clearance.
5. Install the new type cover on the inner adjuster and install your rare unobtainable covers on the outer adjuster.
6. Reinstall your handbrake cables.
7. Put your car up on jackstand and yank the engine so you can be like the rest of us!! <!-- emo&:woohoo: -->
<!-- endemo -->
With one exception... the clearance. There was a typo due to a translation error. The clearance is supposed to be .004, not .008. Setting them to .004 means you get a better pedal, and the park brake handle has a shorter travel to engage the brake.
