Hi,
I had to replace a small section of flexible fuel line back by the engine. About 8" worth. Everything went well. I disconnected the fuel line, the fuel ran out, and I replaced the old line with new.
But when I turned on the ignition the fuel pump doesn't come on briefly and the car won't start.
The fuel pump has been moved to the front of the car so there's no wires to worry about back there.
Does the fuel lines have to be primed or something like that if they get drained? Yes I did put about a gallon of gas back in the gas tank.
Thanks!
