QUOTE(BK911 @ Apr 3 2016, 08:59 AM)
Sloooowly gathering parts to build an engine for my '72 1.7.
Have a set of 2.0 P/Cs but one cylinder is slightly oval. Barely out of spec.
Thinking of using what I have, or boring the cylinders and buy some pistons for a 2056.
If I decide to go 2056, who should I send the cylinders to?
Or just buy new P/Cs?
What would you do?
Assuming that you do
not plan on using FI, then I would use the 2.0 Cyls bored to fit the 96s.
And order the Keith Black pistons from EMW.
And a cam from webcam (86b perhaps?)
However you will need to have the opening in the heads enlarged by a machine shop.
Someone else will need to comment on the wrist pin offset, but I believe it will work fine.
