First up Fiberglass rockers, used, one of them has a crack that needs repaired. $20 plus shipping
Crack is on the underside.
Next up Stock 15mm front swaybar, I am missing a couple parts to make it complete And I half restored these $50 plus shipping
Two 914-4 CV Joint Gaskets
New Tube of Bosch Point Grease
Poly Transmission hangers bushings or early -4 engine mounts.
New Intrepid fan shroud It is yours if you pay shipping! It is ~ 15" x 29" to big for my rad
Poly upper shock bushings and cups / mounts - shocks/struts not part of the deal, just did not take them off.
Yes I have both sides, same condition as this one.
That is all for now. I can also bring with me the Hersey Swap if you will be there, or meet in the Dayton / Cincinnati Area
