Beebo Kanelle
Apr 3 2016, 09:19 PM
My switch for the headlights / instrumentation is shot.
What is the best way to replace it?
Thanks in advance.
Apr 3 2016, 09:24 PM
I pulled mine from the dash and replaced wire by wire. There's also a color diagram on pelican if you get messed up. I did the same wire by wire switch to replace my fuse panel.
Mblizzard
Apr 4 2016, 04:01 AM
Unscrew the knob. Remove the silver retaining nut (slotted) with a coin or other item that will fit the slots and it should drop right out!
jim_hoyland
Apr 4 2016, 07:51 AM
There are two closely related switches: one has ten spades, the other eleven
Beebo Kanelle
Apr 4 2016, 08:03 PM
thanks to all!
