QUOTE(greenie @ Apr 5 2016, 09:31 AM)
After much work on the car this winter a new problem appears.
I got the engine in last week, fired right up and ran for 10 minutes or so, turned off key, no problems.
I took her for a drive, came home and shut it off, it seemed to run for a second after I turned key off, weird but again no problems.
After a long drive yesterday I turn the key off and it continued to run. I popped the clutch to kill her.
I can now turn the key, dash lights come on and off properly but I can hear the fuel pump run continuously until I turn the key off. Is a bad ignition switch going to do this?
I don't think I have a wiring problem since I started and stopped the engine ten times or so without a problem. I was checking a few things prior to this problem, good voltage on battery, alternator is charging properly.
Is this a bad ignition switch or something else?
This small part can cause all sorts of grief, I had intermitent turn signal and wiper issues until it died,was split half way through the plastic housing when I got it out.
Bought the one that Pelican sell seems they are the good ones as mentioned.
