I am in the last stages of rebuilding a 1.8L motor for my 1975 914. I shall be using a 9550 cam from Jake Raby and 96mm pistons and cylinders. Everything else is stock. I plan on using it with the stock L-Jet fuel injection. The engine is aimed to be installed in a daily driver.
I am trying to decide what to do about the compression ratio. From computing it over and over it appears that if I don't put any spacer rings, nor head gaskets, I end up with a CR of about 8.5:1, which is a bit higher than what I originally aimed for (I wanted 8:1 to stay on the safe side). However, if I put the VW recommended spacer rings (1.6mm) between the cylinders and the crankcase, then I end up with a CR of 7.2:1 which is way too low.
Two questions:
a) Would a 8.5:1 with the 9550 cam (fairly mild, only slightly more aggressive than stock) work well on 91 octane gas? Could it perhaps even be run on 87 octane?
b) If not, and I want to get down to 8:1, where can I find spacer rings of thickness of about 0.6mm?
Thanks,
Andrei.
